APC issue
  • APC issue
    Today I did a quick engine cleaning with APC 4:1. However it looks like white streaks are everywhere now. Is this a function of APC? Should I be using Super Degreaser instead?
    AeroCleanse, LLC
    www.aerocleanse.com
    Re: APC issue
    Sounds like it dried up before it was rinsed off? Super Degreaser may stain some plastics and will stain paint. Depends on what you are doing and working on.
      Re: APC issue
      Nope it had not dried up. Working on my engine compartment.
      AeroCleanse, LLC
      www.aerocleanse.com
        Re: APC issue
        Maybe the 4:1 was too strong?
        Those are the only two things I can think of.
          Re: APC issue
          Never seen that happen with APC...... only if it was lefted to dry like Tyler said, would I think it would stain like that. Picture?? I'm guessing you tried to wash the white streaks off and no luck??
            Re: APC issue
            did you wet the surface before applying APC ? A picture would ave better understand...
              Re: APC issue
              4:1 could of been too strong. Try 10:1 first, if it doesn't work, then 4:1. Again, don't let it dry, especially on the paint...Rinse it off completely...
              be sure to cover up intake, altenator, and anything electrical. Safety first.
                Re: APC issue
                I have had the same issue Aero Cleanse.
                  Re: APC issue
                  Originally posted by Carfire View Post
                  I have had the same issue AeroCleanse.
                  I switched to using Super Degreaser on the engine and it doesn't leave the white residue that APC does.
                  AeroCleanse, LLC
                  www.aerocleanse.com
                    Re: APC issue
                    Never have any issue using APC on engines or interiors.
                      Re: APC issue
                      What type of surface? Metal, or plastic?
                        Re: APC issue
                        Plastic
