Gday guys im after some opinions and information regarding these two products.
What i have found so far is:
1) Both products contain the same non dimishing abrasive.
2) M105 has more cut than M86 Solo on any given pad.
3) M86 Solo has longer working time than M105.
4) M86 finishes down flawless with a finishing pad on all paint where as M105 may be too strong (though i have only seen people use a polishing pad with M105)
On the meguiars cutting scale I assume that M86 solo creme is an 8 or 9?
As M86 is pad dependant it seems it can cut anywhere from level 9 cut using a solo heavy cut pad to say a level 2 cut when using the solo finishing pad.
With M105 is it reccomended to use it in a similar fashion as a 1 liquid system? M105 is listed as a compound yet i have seen people using it with a polishing pad and getting near LSP ready.
Would it be possible to use M105 with a light cutting solo pad and then using M105 on a finishing pad to get a flawless finish?
Thanks in advance.
Thanks in advance.
