I've got a black Mercedes that I spent three days on detailing it ... I used clay, M80, M7, and M26 ... I'm sure I did not miss what I seen this morning.
I can't tell if someone rubbed up against it, or if a cat scratch it, or exctly what happened. But there are scraches on the hood and trunk lid, and some others on the sides. I was able to remove the swirls and other scratches before, but not this time. I don't know what the deal is ... here is what I have:
G110A DA Polisher
8006 Polishing Pads
9006 Finishing Pads
M7 Show Car Glaze
M80 Speed Glaze
M26 Hi-Tech Yellow Wax
ScratchX
I tried ScratchX by hand ... I tried 3 times with it on an 8006 pad. I tried 4 times with M80 on a 8006 pad ... just simply no luck at the scratch. I finally went to M7 on a 9006 and M26 on a 9006.
What could I be doing wrong? I start out around 3 on the dial, then speed up to about 4.5 to 5 until it is broken down, or near so - then microfiber wipe -- repeat -- over and over.
I try to put about 15lbs of pressure on the head, but the adapter plate has a white sticker on it, and I can tell that it seems like a clutch sometimes doesn't want to let it spin too well. If I just 'hold/control' the DA with one hand, very light pressure, it will spin but I feel like there is barely any pressure on the pain.
Maybe I am doing something wrong with the DA ... it just doesn't see to want to spin much - most times, my finder touching the side of the pad can stop it.
I know one of you pros could knock this out in no time ... I've seen this question before, but it gets hijacked or something - can someone order these are far as agressivenss for scratches/swirls:
ScratchX, M80, M82, M83
Should I be using a different pad? Is M80 stronger than ScratchX given the same pad type? Several questions about strengths, combinations, and DA performance.
Thanks for any advise!
G110A DA Polisher
8006 Polishing Pads
9006 Finishing Pads
M7 Show Car Glaze
M80 Speed Glaze
ScratchX
