Waxing a camper?
Results 1 to 8 of 8
Thread: Waxing a camper?
    Registered Member Jeepster04's Avatar
    Jul 2006
    Eastern Kentucky
    1,235
    24
    Waxing a camper?
    A camper(pop up) just happened to makes its way into the family. Anyone ever try to wax one of these things? Can you use a regular wax on them? Owners manual states it needs to be waxed but Im not sure how to tackle it.
    Its just the regular aluminum and fiber glass painted with whatever type of paint they use.
    Anyone have any insight?
    Im not really sure what to use on the tents that stick out each end given that I 'should' use something. It would definitely need to be something in a spray can since its so big.
    Here a pic:
    Thanks for any info.
    Registered Member AeroCleanse's Avatar
    Dec 2007
    Neenah, WI
    1,116
    22
    Re: Waxing a camper?
    I would use any spray wax, just treat it like a car.
    37
    18,971
    233
    Might be a good time to use that Detailer Line wax.. cant think of the name offhand.
    Jul 2006
    Eastern Kentucky
    1,235
    24
    X-Press wax.
    Ive got tons of wax I need to use up. Mostly old DC #3 and cleaner wax. It wont be sitting out-doors since we have a building to put it in so that wax should last a good while.
    I was more worried about how this paint reacts to wax. I guess I can wax it just like a car..
    Also, just noticed we have a RV section, didnt know that.
    SYDSTER Sydster's Avatar
    Oct 2006
    44
    1,416
    26
    I guess any wax should work, but do a that spot first in some inconspicuous area.
    SYDSTER
    Jul 2006
    Eastern Kentucky
    1,235
    24
    Ill make sure to take some pics of the outcome.
    The surface is very textured so I have a feeling Im going to have troubles with wax lefted over. We will see sometime this week.
    Jul 2006
    Eastern Kentucky
    1,235
    24
    Here is a picture of it:
    Figured I would use mag&Aluminum polish on the front and rear diamond plate. I only have the mothers Mini power ball so Ill probably just do it by hand.
    Okanagan Valley, BC
    4,544
    391
    Quote Originally Posted by BlueLibby04 View Post
    Morning,
    I would suggest using either Meguiar's #20 Polymer Sealant or from the Meg's marine line, Flagship Marine Wax.
    Be VERY careful around the decals as these will peel off very easily if you are not careful. For the diamond plate, the Powerball works very well, but be prepared to remove wax from around the crevices of the diamond pattern plate. I would probably use NXT Metal Polysh unless you are sure that the diamond plate is not coated.
    Post some pics when done!
    Tim
  1. detailing a 1969 Avian Aluminum camper need help
    By barry in forum Marine/RV Line - Product Discussion
    Last Post: May 18th, 2008, 04:26 AM
  2. Fiberglass camper ?
    By Joe's detailing in forum Detailing 101
    Last Post: Apr 10th, 2007, 01:24 PM
  3. Unloved camper shell extreme makeover
    By geoff in forum Detailing 101
    Last Post: Apr 6th, 2005, 06:02 PM
  4. Camper Detail
    By RockyTop in forum Detailing 101
    Last Post: Mar 23rd, 2005, 08:58 AM
  5. Replies: 3
    Last Post: Sep 9th, 2004, 11:30 AM
