Is this backing plate available seperatly from the SOLO system?
W66 "Easy Buff" Rotary Backing Plate
Re: W66 "Easy Buff" Rotary Backing Plate
Meguiar's doesn't recommend using this pad with our small 6" series pads as it places the edge of the backing plate too close to the edge of the foam pad. Can it be done? Sure. Is it as safe as using the correct and recommended backing plate for the foam pad? No.
We'll take some pictures to show the difference...
The point of these pictures is to try to show you how much margin of safety you lose when you use the W66 instead of the W64 backing plate when using any of the 6" pads i.e. W-7006, W-8006 and W-9006
W64 Rotary Buffer Backing plate for our 6" foam pads
Look how much more foam there is sticking out past the backing plate.
These two shots are of the face of the W64 Backing Plate placed against the face of the W66 "Easy Buffing" rotary backing plate.
Thanks Mike. So you mean to say it's not recommended but it can still be use, just that I have to be extra careful with it.
My concern is actually would it damage the pad where the face of the bp/velcro is in direct contact with the foam?
Originally posted by KrisMas View PostSo you mean to say it's not recommended but it can still be use, just that I have to be extra careful with it.
Originally posted by KrisMas View PostMy concern is actually would it damage the pad where the face of the bp/velcro is in direct contact with the foam?
Best thing to do at this time is used the correct backing plate for the pad you want to use.
