Page 7 of 7 FirstFirst 1234567
Results 61 to 64 of 64
Thread: **New** Meguiar's #105 Ultra Cut Compound Review!!!!
  1. #61
    52
    24,964
    514
    Re: **New** Meguiar's #105 Ultra Cut Compound Review!!!!
    Quote Originally Posted by andrewc_11890 View Post
    Excellent write up.
    Is it only advised to use 105 with a rotary or will it work with a DA (and what type of pad)
    I was at the meguiars Open Garage Last night and I remember there was a bmw with some major imperfections in the hood. They tried multiple products with the DA but I don't remember if they tried 105 with the DA. However they eventually took out the Rotary and used some 105. I think that was followed up by some 2 to remove any hazing and a bit of polish. Then it was followed by NXT 2.0, It looked amazing!
    Mike Stoops can clarify what was used on the BMW but the question should probably be posted to the pictures and comments thread for the class last night.
    Last Night at Meguiar's Garage!
    Full house last night which ended with two cool Fords getting
    warmed over at Meguiar's Garage!
    Click here to read more or add your comments...
  2. #62
    20
    9
    Quote Originally Posted by Tim Lingor View Post
    Cool! You will love the product!!!!!
    Tim
    Tim,
    I would like to see you try it with a DA, as some of us do not own a rotary, but do need a little more help some times. It would be nice to see which pads and speeds used what this stuff could do on water spots bird dropping etc. I have a Thunder Gray Tundra that when done up right has a un believable finish in the sun, or under street lamps. But I would like to take it to the next step, so I can learn and keep up it's replacement finish on a high note also.
    Kevin
    Kevin
  3. #63
    92mr2
    Jul 2008
    Winona, MN
    14
    5
    That was a very helpful write up!
    I'm working on a '99 Lexus ES300 black and scratched to the max. Beautiful leather inside and only 113K but the paint.....heartbreak.
    I started with scratchX and went to #2 fine-cut cleaner and it's coming but maybe 105 would be better.
    Question: When using #2FCC I apply it till it starts to clump up and begins to squeak.............and then wipe off.
    Is the squeaking a normal thing? This paint has no clear coat.
    Thanks
    Bob
  4. #64
    HID Guru Megafast13's Avatar
    Aug 2008
    Cincinnati, Ohio
    20
    1,703
    27
    Amazing write up!
  1. M105 Ultra Cut Compound - New!
    By Mike Phillips in forum Professional Line
    Last Post: Sep 6th, 2009, 12:47 AM
  2. Meguiar's *New* M105 Ultra-Cut Compound Makes a SPLASH at Alpine Electronics
    By Kevin Brown in forum Show Off Your Latest Detail Work
    Last Post: Sep 5th, 2009, 04:35 AM
  3. #105 Ultra Cut Compound - Help Needed
    By jamores23 in forum Professional Line
    Last Post: Feb 21st, 2009, 03:40 AM
  4. M105 Ultra-Cut Compound Kit - New
    Last Post: Mar 27th, 2008, 12:25 AM
  5. Ultra-Cut Compound 105 in Action
    By Sydster in forum The Break Room
    Last Post: Mar 9th, 2008, 08:29 AM
