Re: What's the deal with "Layering?"
Yes. Technically you only need to apply one application of wax or paint sealant as long as;
So as long as you're cleaning and prepping the paint correctly before waxing, and as long as you're doing a great job of applying the first coat, you technically don't have to apply a second coat. If you're unsure of your how thoroughly you apply the first coat, then you can as an option apply a second coat and the idea is that through the application of the second coat every square inch of paint will have been adequately had wax applied and dried to it.
One coat if you're doing a great job of applying the product, two coats as an insurance policy to insure uniform coverage over all the paint.
This information in this thread is for the most part timeless and applies to most all products when it comes to the topic of layering. When a product comes out where the average end-user can can truly layer a product where with each layer a measurable increase in thickness occurs, and the layer they're creating is not opaque, that is it is 100% optically clear so that the paint underneath is not being clouded in any way, well then this product will be the talk on ALL the forums and everyone will know about it in about 24 hours.
(If you hang out on detailing forums).
You don't have to top NXT or any of our waxes or paint sealants with another one of our waxes and paint sealants.
NXT And M21 are kissing cousins with the primary difference being M21 is formulated to perform well when used with a rotary buffer where dramatically more heat can be generated during application.
Is it a wax? Or a paint sealant?
(Just to note, it's not a good idea in general to apply waxes with a rotary buffer if the goal is a swirl-free, flawless finish but we make our Professional Line products like this because that's how waxes are applied in the Production Detailing industry where speed is usually more important than true swirl-free finishes.)
You can maintain your car's finish no matter which Meguiar's wax or paint sealant you use by using ANY of our spray-on waxes including our new Ultimate Quik Wax.
As long as you apply a thin coat, allow it to fully dry before removing and use a soft, fluffy bonnet on your polisher, NXT should wipe off very easily.
How to tell if wax is dry and ready to remove...
The Swipe Test
Originally posted by Bruclee
View Post
- The surface is clean and ready for sealing with a wax or paint sealant.
- The person applying the product does a great job over applying and working in a thin, even layer over each square inch of paint.
- Insure uniform coverage
- Insure uniform appearance
View Post
View Post
View Post
The Swipe Test
