Features
- Powerful 3.3-Amps, 4,500-12,000 OPM Speed Range — Ensures fast, smooth results on all surfaces
- High-performance Microcellular Backing Pad — Conforms to contours, provides a fine finish
- Integral pad dampening system — Helps prevent swirl marks for consistent fine finish
- Uses 8-Hole 5" Hook and Loop Discs — Compatible with industry-standard discs
- Rugged Die-cast Aluminum Gear Housing with exclusive dual-bearing pad mount — Long-life design eliminates wobble and vibration
- Through-the-pad dust extraction — Pulls dust away from work surface to maximize sanding efficiancy and extend paper life.
- Bosch Microfilter Dust Canister with integrated paper filter — Optimal system for filtering fine dust. Captures more dust than competitor models. Traps particles as small as a 1/2 micron in diameter.
- Variable-speed dial — Allows match of speed to workpiece and task
- Soft-start — Reduces start-up torque
- Tapered Soft-Grip Top, plus ergonomic handles for comfort and control — Tapered top matches natural hand angle. Multiple grip positions prevent fatigue. Front handle removes easily for sanding in tight spots.
- Constant Response™ Circuitry — Maintains constant speed under load, provides overload protection
- Trigger with lock-on button — For extended periods of use
- Double insulated
- Pad Wrench 5mm Hex 1 907 950 006
- Soft Backing Pad -- RS031
- Sanding Disc --Included
- Microfilter Dust Canister -- RS026
