Air vs. Electric polisher
Results 1 to 10 of 10
Thread: Air vs. Electric polisher
    Jan 2008
    31
    12
    Well, I have been on the fence. When it was announced on the forums last year, I was ready to go for a G110. Now I am again undecided and need help.
    I have read in the archives the reason for using a PC due to cost portability. I will not be doing this for money but will have a compressor. Can you help me choose between a G110 and an air tool? What recommendations for the air tool for a newbie? I have no idea about the quality and availability of tools to run using a compressor.
    Thanks in advance for any feedback.
    21,386
    1136
    Re: Air vs. Electric polisher
    What's the capacity of the compressor you'll be using? Can you run a piece of equipment non stop for a few minutes at a time with very short off cycles between loads? From what I've seen most smaller home compressors won't cut it for this application.
    I had the opportunity to use a new G110 last week for several hours and I love it! Sort of wish my Porter Cable 7424 would break so I'd a reason to buy one!
    Okanagan Valley, BC
    4,544
    392
    I agree with Mike. Unless you have a compressor with a high CFM and a large storage tank, you will hate using the air DA.
    Though I am not able to comment on it, I used the G110 after the SEMA show. In fact, I think mine was the one on display. In a week or two, I will be able to post more info once I have been given the OK from management.
    Tim
    Nov 2004
    SoCal
    2,298
    40
    Cool Re: Air vs. Electric polisher
    to MOL, somarr!
    Quote Originally Posted by somarr View Post
    ... What recommendations for the air tool for a newbie? ...
    Good question. Most newbies worry about the cost of a G100. I haven’t come across one looking to spend the big bucks on air tools and the honkin’ compressor it takes to run them.
    Anyway, whether for newbie or old pro I’d still recommend the same commercial quality tools form companies like Dynabrade, National Detroit and Hutchins.
    But really, unless you know you specifically want pneumatics, you'll probably be happiest with electrics.
    PC.
    Person PorscheGuy997's Avatar
    Apr 2006
    Southern Indiana
    1,344
    33
    Just curious, what size compressor does it take to efficiently run an air polisher? How about the PSI?
    I've considered to getting a DA sander (Mirka or Dynabrade) to use along with my 20 gal compressor for a project.
    Chris
    Dasher Detailing Services
    Registered Member onawrxhigh's Avatar
    Jun 2004
    Ocean County NJ
    44
    618
    21
    I would also think that the noise of the air da would be too loud for prolonged use without having to use hearing protection. I know I don't like using my air impact gun even for short bursts while rotating tires.
    Andrew
    2013 Race Red F-150 SCREW
    Okanagan Valley, BC
    4,544
    392
    Quote Originally Posted by PorscheGuy997 View Post
    It depends on the DA you are planning to use. The Dynabrade with the 3/16" orbit requires 14 SCFM at 90 PSI. Now that does not mean you can not use it in small bursts, with a smaller air compressor. But that depends on how small of compressor you have.
    I have a 5.5 HP, Dual Stage with cast iron head and a belt drive. It puts out 5.8 SCFM at 90 psi with a 30 gallon tank and I find it inadequate for many air tools.
    Tim
    Apr 2006
    Southern Indiana
    1,344
    33
    Wow, I guess it takes a lot of power to use one of these then!!!
    Thanks for the info Tim!
    Chris
    Nov 2004
    SoCal
    2,298
    40
    Quote Originally Posted by onawrxhigh View Post
    Andrew
    An impact wrench is especially loud because it’s not just spinning, it’s hammering. An air DA doesn’t seem louder than en electric (not that I’ve measured it) but the sound is more of a hiss than a buzz. I tend to wear ear plugs with either air or electric.
    PC.
    Jan 2008
    31
    12
    Sorry. When I mentioned cost, I meant the cost of a compressor and its associated tools. From what I read on the forums, that is why the PC/G110 is recommended. You just have the cost of the tool.
    As far as the specs on the compressor, I am not sure. I will check into it. If I can recall, I is only a 26 or 30 gallon. I am not sure of PSI but I thought the most important measure was the CFM as mentioned above.
    So, I may still end up with a G110. I will have to get the specs. I just wanted to take advantage of the compressor if I had it. I already figured out the obvious that I would be stuck detailing the family's vehciles at my house or lugging the compressor around. The G110 wins hands down to that respect.
    Again thanks for everyone's replies so far. I was also wanting to take everything into consideration before making a decision. Yet another lesson learned from the forums. I coin acronyms all the time at work. Maybe this needs to become one. A "YALL" - Yet another lesson learned....
  1. G110 Electric Dual Action Polisher Kit + Extras ($148)
    By helixblue in forum For Sale or Trade
    Last Post: Nov 2nd, 2008, 05:14 PM
  2. Chicago Electric 6" waxer/polisher
    By openthewell in forum Machines - The Rotary Polisher
    Last Post: Jan 9th, 2007, 10:40 AM
  3. Mequiar's Electric Dual Action Polisher question
    By se93 in forum Detailing 101
    Last Post: Dec 26th, 2005, 08:46 AM
  4. DA air polisher?
    By BuckeyeMCS in forum Detailing 101
    Last Post: Oct 25th, 2005, 05:52 PM
  5. What electric polisher/buffer????
    By mattfletcher in forum Detailing 101
    Last Post: Jan 13th, 2005, 02:10 PM
