I have a clearcoat finish, so what and how do I use to get the bugs off?
How do I remove bugs from front of SUV?
Re: How do I remove bugs from front of SUV?
The below thread can be found in Hot Topics
http://meguiarsonline.com/forums/showthread.php?t=16053
I found that if you pre-soak those areas with wash solution they come off. If they are old or particularly stuck on, then using a clay bar can help. I've found that hot water with the correct ratio of car wash works just fine. I used to dilute the car wash way too much.
I am a big skeptic when it comes to "magic" sprays etc.
I broke down and bought some Gold Class Bug and Tar Remover. I sprayed some on as directed, used my handy cut up terry cloth and after following directions.....The bugs came off quite easily and little effort.
This was on a 2001 Ford Excursion that runs on ranches and country roads in our area. Covered in bugs.
AaronPhilippians 2:14 - Do all things without grumbling or questioning,
You guys are a life saver...I've got the SUV in the garage so not to bake the bugs into the paint. I just got back from a very long trip in the midwest and hit the bugs in Florida last night. Hope to try the suggestions out tomorrow.
Thanks again.
Just to note, the wet wash rag/towel suggestion is for baked on bugs and people who want to do everything they can to soften and loosen the bug guts so they don't have to "scrub" on the paint to prevent possible scratching.
Not everyone will want to get this AR
Originally posted by Mike Phillips View PostJust to note, the wet wash rag/towel suggestion is for baked on bugs and people who want to do everything they can to soften and loosen the bug guts so they don't have to "scrub" on the paint to prevent possible scratching.
