Results 1 to 8 of 8
Thread: Did I mess up my headlights?
    Apr 2007
    Antioch, IL
    123
    8
    Hey guys,
    I am really in need of some advice. I have a 2007 ACURA TSX. I noticed today that I had some scratches on my headlights. They were not bad, but if the light caught them right, you could see them. Since I am really anal about my car, I was determined to get these out. So, I initially started with some liquid glass wax. I thought maybe that would help to cover them up. That didn't do anything, so I tried SCRATCH OUT by KIT (yellow bottle). That helped a little bit, but didn't do a whole lot. So, I went to Autozone and picked up some PLASTX. Anyway's, this didn't seem to do much either. Now, my headlights look clear, but I swear when I have my headlights on (HIDS w/ projectors), I swear the light looks kind of like fuzzy on the garage door. Maybe it's just me, but I am really worried that I might of permantely screwed up my headlights. Will any of the products that I used PERMANENTLY mess up the plastic on my headlight housing? Also, on one of the headlights, the PLASTX kind of dried, so I moistened an applicator pad and buffed it off, then used some invisible glass window cleaner to buff it off. Is there anyway to permanently remove it, or would that have done so? Also, is it pretty common for headlights to have scratches (drying the car, etc)? If anyone could be of some assistance, that would be wonderful!
    Thanks,
    Jeff
    Registered Member travisdecpn's Avatar
    Apr 2004
    756
    17
    Re: Did I mess up my headlights?
    It is possible that in your effort to remove the light scratches you have instilled some micro-marring. What type of applicator did you use to apply these products? In my experiences with Plastx, using a foam applicator pad and light pressure yield great results. A second application of Plastx applied with a foam pad and allowing the polish to break-down completely should resolve your problem. Good luck.
    Apr 2007
    Antioch, IL
    123
    8
    Thanks for the response, Travis. How could I tell if Micro-marring occured? I will definitely have to try another application of it tomorrow, and see how it works. I believe that I used a 100% cotton applicator pad to apply it.
    Apr 2004
    756
    17
    Micro-marring is essentially thousands of tiny scratches that usually occur when a polish has either not broken down enough, or in your case broken down to the point of drying out. Under direct sunlight you will see these scratches and the headlights will appear slightly hazy. The second application should help remove the micro-marring.
    Apr 2007
    Antioch, IL
    123
    8
    Travis, providing that another application of it does not help, then what do I do? Also, when you apply the PLASTX, do you apply it to the whole headlight at once, or do like half of the headlight, wipe off the residue, then proceed to do the other half? Perhaps I've been doing it wrong? Honestly, it was probably REALLY stupid of me to do this, but I did...
    Aug 2006
    Yreka, CA
    3,533
    180
    I use the little Meguiars foam applicators on my headlights with no marring and use a MF cloth to remove the PlastX. They turn out awesome. Do like they say, do half a headlight then compare.
    Good luck.
    Aaron
    Apr 2007
    Antioch, IL
    123
    8
    It's funny, because I thought that my headlights looked kind of hazy last night, but today in the sunlight they appear crystal clear. I guess my question is, if I were to have micro-marred the headlights, wouldn't they look kind of hazy when you looked at them?
    Self-Banned TrufflePig's Avatar
    Apr 2006
    1,247
    0
    Quote Originally Posted by JLTSX07 View Post
    Hey guys,
    Thanks,
    Jeff
    why is it pretty common for headlights to have scratches through washing.
    two bucket method. nice soft mitt. and you're good.
    is it possible you didn't work the product good enough or worked it to much?
    try a good cleaning with the Pro Line and see if that helps.
  1. Anyone mess with powdercoat?
    By Duneroller in forum Marine & RV
    Last Post: Aug 12th, 2008, 09:13 AM
  2. trim mess
    By j&mdetail in forum Detailing 101
    Last Post: Mar 1st, 2008, 06:27 PM
  3. First time mess up
    By Thejoyofdriving in forum Detailing 101
    Last Post: Mar 12th, 2007, 08:37 AM
  4. 02 Celica was a mess!
    By dietoremain in forum Show Off Your Latest Detail Work
    Last Post: Jan 27th, 2007, 03:43 PM
  5. Ugh...what a mess.
    By rascal in forum The Break Room
    Last Post: Aug 16th, 2006, 10:50 AM
