Results 1 to 4 of 4
Thread: Applying #16 w/polishing pad
    Why do I smell bananas Don's Avatar
    NE Ohio
    46
    1,019
    20
    I've always used a finishing pad to apply #16. One of the things I didn't like was how much wax was absorbed by the pad, affecting how well the #16 speads.
    Today I tried a LC white 'polishing' pad to apply a coat of #16 to the car. All I can say is WOW!!!. The "spread forever" characteristics of the #16 that I love so well is back with a vengence. I use more butter on two pieces of toast than it took to put a medium thickness coat of #16 over the entire car!
    I let the #16 sit for about 2 hours while I took care of a few "honey-do's" When I got to removing the dried wax, I found that while it was more difficult than a very thin coat, but I noticed that if I just went after small 'bites' then buffed the whole panel after the "big stuff" was gone, the finish was perfectly glossy, smooth and smear-free.
    I think that while an extremely thin coat of #16 is easier to remove, a slightly thicker coat gives better protection. Too, the polishing pad is definately the way to go for application.
    Don
    "Racy Red"
    2006 Suzuki Aerio -
    The funny-little car that's A LOT faster than it looks.
    Okanagan Valley, BC
    4,552
    386
    Hey,
    Firstly, I would prefer to use the least aggressive pad to apply any Last Step Product. As such, I would use a W-9006 Finishing Pad. The more aggressive of pad, the more the chance of instilling micro-marring. Now, while the W-8006 pad is not that aggressive, and is an excellent, all-around pad, I would still use the least aggressive pad I could find. Just IMHO!
    Secondly, whether thick or thin, you should get the same protection from a product. When the residue is wiped off, only a certain amount will remain behind. As such, IMHO, a thicker coat just wastes product.
    Tim
    NE Ohio
    46
    1,019
    20
    I understand what you're saying, but the total amount of wax I used from the can wouldn't quite have filled 2 of those little coffee creamers that you get at the convenience store coffee machines. I guess what I mean is a thick coat as opposed to trying to put a carnuaba on as thin as a sealant. When the coat dried, it wasn't white and chalky like a carnuaba gets when it's applied too thick, it was still clear when fully dried.
    As for the polishing pad, even Mike P uses one to apply NXT, and since the #16 is a "heavy" wax (again per Mike P...I'll check for his post on this...it wasn't too long ago) I feel that it has more than enough lubricating qualities while it's being applied to offset any risk of micro-marring from a slightly more aggressive pad.
    Don
    "Racy Red"
    2006 Suzuki Aerio -
    Okanagan Valley, BC
    4,552
    386
    Hey Don,
    Actually, Mike uses a W-9006 Finishing Pad to apply the NXT Tech Wax. In the beginning he used a W-8006 pad with NXT, but now uses the W-9006. If a car has a few light swirls remaining or is not in excellent condition, then a W-8006 pad may be a good idea.
    But, the W-9006 does absorb more product than a W-8006, at least until it becomes somewhat saturated.
    Tim
  1. Applying M21 2.0 on a yellow pad 2.0
    By TimG in forum The Dual Action Polisher
    Last Post: Aug 5th, 2008, 08:10 AM
  2. Which pad for applying ColorX
    By hipocket in forum The Dual Action Polisher
    Last Post: Feb 27th, 2008, 03:24 PM
  3. applying colorX with g100... what pad??
    By tripmachine in forum Detailing 101
    Last Post: Jul 24th, 2006, 12:10 PM
  4. Polishing pad
    By Djmigs in forum The Dual Action Polisher
    Last Post: Oct 26th, 2005, 08:00 PM
  5. Cutting Pad vs Polishing Pad & DA
    By Question Boy in forum Detailing 101
    Last Post: Apr 10th, 2005, 01:38 PM
