Can I effectively detail under 40 degrees?
  • Can I effectively detail under 40 degrees?
    As it says- will it compromise the integrity of the product I use? (within reason- I wouldn't do anything at 5 degrees...
    Why do I wax more than I drive?
    1991 Ford Taurus SHO Red/Black
    2004 Ford F-150 Black/Gray
    Re: Is this too far gone?
    It will be a lot of work but you should be able to get it back in pretty good shape, probably not new car condition, but much better...
    Good luck!!!
      huh, thats weird, i typed this under your other thread about the taurus and it showed up here...the reply posted here was for the other thread..sorry
        Re: Can I effectively detail under 40 degrees?
        I just noticed that... No problem, internet hiccup? Who knows...
          yeah, its really wierd...never happen before
            I tried to detail my truck when I first got it and it was aroung 35 degrees. I though I had good results until I detailed at 60 degrees. I think the surface temp played havoc on the products and I probaly wasn't putting in as much effort at that temp.
            Erick Lawson
            2007 Ford F-150 / 2004 Infiniti G35
              In the apartment complex I am at the garage is only about 45 degrees. Which is warm enough to wash a car but drying them becomes an issue. Nothing wants to dry properly (I use water magnets or cheap microfibers). A little QD or NXT Speed Detailer helps but it still is a pain.
              I did wax with NXT a few weeks back and it applyed fine and dryed fine, but 30 does seems a little low for most products.
              "Difficult takes a day, impossible takes a week." Jay-Z
