Cleaning Plastic Wheel Covers
Results 1 to 10 of 12
Thread: Cleaning Plastic Wheel Covers
    Jan 2007
    21
    12
    Question Cleaning Plastic Wheel Covers
    I have a 07 Honda Civic with the plastic wheel covers. Is there any wheel cleaning product that I can spray on these gray plastic wheel covers that will not damage them yet make it easier to remove the brake dust and road grime? They can really get nasty after a little while and I'm not in the best physical condition ( old ), so its difficult for me to get down there and clean all those little crevices. Any help would be welcomed. Thanks guys.
    Robert 96
    Registered Member JG_Detailing's Avatar
    Apr 2004
    Waynesburg, Pa
    46
    1,799
    36
    Re: Cleaning Plastic Wheel Covers
    I spray on tire cleaner and use a tire brush on them.
    Jan 2007
    21
    12
    Wink Re: Cleaning Plastic Wheel Covers
    Thanks Cobalt. I'll give that a try.
    Robert 96
    Apr 2004
    Waynesburg, Pa
    46
    1,799
    36
    Your welcome!
    Sep 2004
    1,521
    29
    you could use this as it's very gentle...
    Introducing a safe way to clean delicate wheel and brake components. New Hot Rims Multi Piece Wheel Wash is a non-alkaline, non-acid formula designed to safely remove grime, grit and brake dust from all polished/unpolished aluminum,powder-coated, multi-surface or anodized wheels - also safe on all aftermarket brake components including calipers and rotors. Helps break down stubborn road residue with our Hot Rims unique foaming agents. Our Xtreme Cling™ foam is designed to cling vigorously to vertical surfaces and helps to lift and separate dirt from your wheels.
    Jun 2006
    164
    yea but is the multi piece plastic safe?
    Jan 2007
    21
    12
    Thanks IMACARNUT. That multi piece stuff sound like it should be mild enough. Does anyone know differant?
    Robert 96
    Registered Member astaticwinter's Avatar
    Aug 2006
    31
    26
    12
    I've used that also on my old ASA rims that were clearcoated, and it did a great job, never any hint of damaging...so it's nice and safe. I'd say that if it's safe on clearcoat, it'd be safe on plastic hub caps as well.
    I gave it a shot on my girlfriends hubcaps on her Escort without any problems, it broke up all the grime, and I used the wheel face brush and it all came off without any problems, so it's nice and strong, but very safe.
    Hope this helps.
    2003 Matrix XRS *Sold*
    2002 Mustang GT
    2005 Subaru STi *coming this spring!*
    Jan 2007
    21
    12
    Smile Re: Cleaning Plastic Wheel Covers
    Thanks Astaticwinter. All these postitive E-mails are really making me want to go out and clean my wheels. The only problem is that it keeps snowing here in Cincinnati with frigid temps. and lots and lots of road salt! I'm waiting for that first warm day. Thanks again.
    Robert 96
    May 2006
    112
    14
    A while back I had a mishap with a tire cleaner. (non-Megs - what was I thinking?)
    Results below:
    These stains were tough. Anything by hand would have probably taken 4-5 hours per wheel.
    So I used my Dremel, a home made 1-inch pad and M80 to get the stains out.
    After the stains were gone I gave them 3 coats of NXT (3 just to be really sure)
    They responded really, really well to this process. They are extremely easy to
    clean now. Much easier than when I just had NXT on them. Since they have been polished with #80 stuff just doesn't stick as well.
    If you try something like this, please use eye protection.
    My assembly never flew apart but it could have. Plus at 5000 RPM sling will travel.
  1. scratching on a plastic wheel guard
    By msawert in forum Detailing 101
    Last Post: Dec 5th, 2008, 08:52 AM
  2. Polishing windscreen and plastic headlight covers
    By genee in forum Detailing 101
    Last Post: Aug 16th, 2006, 11:42 AM
  3. Cleaning ABS plastic wheel covers
    By str8razor in forum Detailing 101
    Last Post: Jun 25th, 2005, 05:41 AM
  4. cleaning the clear plastic behind the steering wheel ..
    By SprintKing in forum Headlight Restoration & Clear Plastic Detailing
    Last Post: Mar 12th, 2005, 03:19 PM
  5. clear coated painted wheel covers
    By denetc in forum Detailing 101
    Last Post: Mar 13th, 2004, 07:58 AM
