Results 1 to 10 of 18
Thread: Wet Sanding: Plain water, or water + "soap"?
    Oct 2006
    San Pedro, CA
    766
    23
    As the title say, how wet sanding is done, with water and lubricant ("soap") or it is done with plain water? I am asking because I've "heard" of people using water and soap, and at the same time as I am looking at Wet Wedge (that I am considering getting) videos I see everybody is using just plain water.
    Thank you in advance!
    Registered Member 98blackbird's Avatar
    May 2006
    64
    12
    Re: Wet Sanding: Plain water, or water + "soap"?
    you can use either. what are you wet sanding, primer or paint? when sanding primer your paper can get clogged up very fast, so if you use soap it helps keep the sandpaper clean longer. I've never had a problem with paint(clear coat) clogging up my sandpaper, so i just use plain water. I wouldnt suggest using dish soap while sanded on a freshly painted car because as you can find on these forums, the paint needs to breathe and if you use dish soap it wont allow it to do that.
    56
    24,797
    517
    A little soap in the water helps to,
    Lubricate the surface
    Prevent your sanding paper from clogging up
    Enable particles to rinse more freely off the surface
    Meguiar's has been offering a special wet-sanding soap for about 30 plus years, use just a little in your bucket, like a capful or two for about 3-4 gallons.
    This is a low sudsing soap that is completely safe for all fresh paint. By the way, all of our car wash solutions are safe for fresh paint. (Less than 30 days old).
    Hi Tech Wash
    Oct 2006
    San Pedro, CA
    766
    23
    Quote Originally Posted by 98blackbird View Post
    Thank you! I will be wet sanding paint.
    Oct 2006
    San Pedro, CA
    766
    23
    A little soap in the water helps too
    Thank you Mike! I assumed soap in water used to wet area as I am working would be beneficial but I can not do that with Wet Wedge, right?
    Grill Master kellyinkc's Avatar
    Jul 2005
    1,597
    28
    Quote Originally Posted by ZoranC View Post
    What is a wet wedge?
    MOL- Welcome to the world of real detailer's
    Oct 2006
    San Pedro, CA
    766
    23
    Quote Originally Posted by kellyinkc View Post
    Commercial Link removed -Mike Phillips
    Nov 2004
    SoCal
    2,280
    39
    Cool Re: Wet Sanding: Plain water, or water + "soap"?
    ...I assumed soap in water used to wet area as I am working would be beneficial but I can not do that with Wet Wedge, right?
    I always figured that if I got a WetWedge I’d try to rig up a water source with soap instead of just running it off the tap. Maybe you could use a pump sprayer tank, or a dilution gun or something like that.
    PC.
    Registered Member OctaneGuy's Avatar
    47
    670
    20
    I used a 0.5 gallon bug sprayer. The hose on the WetWedge has the same ID tubing as the sprayer, so it fits. You probably want to find a way to clamp it as well.
    I did this to demo the WetWedge at NACE where we didn't have access to a water spigot. You could fill it with soap water solution if you wanted to.
    Richard
    Quote Originally Posted by the other pc View Post
    PC.
    Richard Lin
    ShowCarDetailing
    5548 E. La Palma Ave
    Anaheim, CA 92807
    toll free: 866 707 9292
    Nov 2004
    SoCal
    2,280
    39
    Dang, beat me to it!
    Thanks Richard!
    PC.
  1. Replies: 20
    Last Post: Sep 17th, 2008, 11:01 PM
  2. The " Wet " Look for a silver
    By 18611 in forum Detailing 101
    Last Post: Mar 21st, 2007, 03:35 PM
  3. What is the "best" water to use for washing a car?
    By mckeand13 in forum Detailing 101
    Last Post: Jan 25th, 2007, 12:56 PM
  4. "California" water blades
    By emaxxman in forum Detailing 101
    Last Post: Jun 14th, 2006, 03:33 PM
  5. Mike, tell me about Australian cnsumer product "Wet Look Polymer Sealant", please?
    By Mosca in forum Consumer Line - Product Discussion
    Last Post: Sep 5th, 2004, 12:43 AM
