Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Speed question....G100 vs rotary....
  1. #1
    Formerly "n737nc" Nick Chapman's Avatar
    Join Date
    Sep 2006
    Location
    Dallas, Texas
    Age
    41
    Posts
    2,700
    Rep Power
    305
    If you have the G100 set on speed 5, what would be the equivalent speed on a rotary? I know they are 2 different beasts, but what speed on the rotary would give the same results of a G100 set on speed 5? Same pad, same product.
    2008 Meguiar's Batmobile Team
    2008 Meguiar's/Ford SEMA Team
    2009 Meguiar's/Ford SEMA Team
    2010 Meguiar's/Ford SEMA Team
  2. #2
    Registered Member Chex's Avatar
    Join Date
    Mar 2005
    Age
    27
    Posts
    269
    Rep Power
    11
    Re: Speed question....G100 vs rotary....
    If you use a number dial rotary buffer, like the G100, if set at 5 you would be probably working like at 2500-2700RPM which would kill the paint instantly with a bad move and especially when compounding with a wool pad.
    as far as i know, no professional care care product manufacturer recommends speeds above 2000RPM's.
    I've never used a PC, but I'll get one this christmas as an obligatory self present however, i've seen that speed 5 can remove up to medium defects with M83, so your equivalency to a rotary starts from 1200RPM and ends in 2000RPM.
    if you're doing mild polishing and you're not very familiar, start with 1200RPM. if you're familiar, do your jobs with 1400RPM's and medium pressure.
    if you're familiar and want to do nice polishing with more defect removal capabilities, step to 1800RPM and medium pressure too.
    just remember the PC principles: keep the buffer moving and work your product "wet"
    you can also check the first or second post (don't remember which one is it :P) which tells you the recommended pads and speed ranges for meguiar's products. if you work with 3M products, set your standard to 1800RPM's (recommended buffer speed for compounds and polishes)
    Hope this helps.
    " Sometimes logic is your friend (Mike-In-Orange)"
  3. #3
    Join Date
    Sep 2006
    Location
    Dallas, Texas
    Age
    41
    Posts
    2,700
    Rep Power
    305
    Thanks Chex!
    I've got both the G100 and the Makita rotary, and no matter how many times I either one of them, I'm still learning. I just bought the Makita not too long ago, and I'm loving the results I get from it combined with the G100.
    What I'm looking for is if I use the G100 on speed 5 with 80 Speed Glaze, it would be the same as using the rotary with 80 at xxxx rpm's. Does that make a little more sense?
  4. #4
    Who? Me? the other pc's Avatar
    Join Date
    Nov 2004
    Location
    SoCal
    Posts
    2,169
    Rep Power
    33
    Cool Re: Speed question....G100 vs rotary....
    Quote Originally Posted by n737nc View Post
    If you have the G100 set on speed 5, what would be the equivalent speed on a rotary? ....
    There is no such thing. Since the two machines work in very different ways you can’t directly compare them that way.
    It might possible to compare one specific aspect of operation at two different speeds, total material removal rate averaged over the entire worked area for example, if all other factors are held constant; paint, product, pad, downward pressure, arm speed surface area covered, overlap pattern, etc, etc. But everything would be totally different if you changed even one of them.
    Of course in the real world of actually working on cars you’d never change just one piece of the overall puzzle.
    PC.
  5. #5
    Join Date
    Sep 2006
    Location
    Dallas, Texas
    Age
    41
    Posts
    2,700
    Rep Power
    305
    Hmmmm, let me try another approach. If you worked 80 in with a PC say 4 passes. At what speed would the rotary give the exact same results in the finish?
    I know these 2 are entirely different machines, and I'm not looking for an RPM comparison. What I'm looking for is a point at which these two machines would give the exact same results on the paint's finish. PC on speed 5 and a rotary on xxxx rpm's.
  6. #6
    Join Date
    Nov 2004
    Location
    SoCal
    Posts
    2,169
    Rep Power
    33
    What I’m saying is that that speed is different for every paint, every pad, every hand pressure, every arm speed and who knows what else.
    You may never get the exact same results in the finish. You may be able to remove paint at the same rate but still get a different finish characteristic.
    PC.
  7. #7
    Join Date
    Mar 2005
    Age
    27
    Posts
    269
    Rep Power
    11
    maybe (can't precise the result much because i've never used a PC) I would say one pass with a rotary @ 1400RPM woud be an equivalent to two passes with the PC @ speed 5.
    however if you did a pass with the rotary first, and with the PC second, you would get superior results and with a little or no swirls: a thing that is pretty tough to acheive using a rotary only.
  8. #8
    Join Date
    Sep 2006
    Location
    Dallas, Texas
    Age
    41
    Posts
    2,700
    Rep Power
    305
    Ok, thanks guys! Thats the info I was looking for.
  9. #9
    Registered Member Zet's Avatar
    Join Date
    Apr 2006
    Location
    Denmark
    Posts
    215
    Rep Power
    10
    If you were using the same product and pad, the rotary would typically be much more effective/agressive at defect removal even at it's lowest speed, compared to the PC at any speed. But at the same time I find that the rotary leaves a nicer finish, if you are able to avoid holograms/buffer swirls. This again depends on the actual paint, product, pad, speed and technique you are using etc. For the PC it takes a lot longer to properly break down the polish, so the work time between the two machines is also very different.
    I really don't think you can compare the two machines like that. Often it might take something like #83 on a polishing pad with the PC, to have the same defect removal ability as say #80 on a polishing pad with the rotary. But between these two combos, the rotary would leave a much nicer finish.
    Each machine has it's purpose. IMO the PC wins on ease of use and safe operation. The rotary wins on speed/effectiveness and the finish it leaves behind.
    "Now Biff... make sure that we get two coats of wax this time..."
    - Back To The Future
  10. #10
    Join Date
    Sep 2006
    Location
    Dallas, Texas
    Age
    41
    Posts
    2,700
    Rep Power
    305
    This is just something I was curious about. As I am just learning to use the rotary(3 complete cars down now), I was just looking for info on when to actually break out the rotarty on a car.
    Say if I do a test spot on my hood, and it takes 2 passes of #83, then 1 pass of #80, I would know in my head that I could achieve the same results with 1 pass of #83 with a rotary on xxxx speed, then move on to the PC for 1 pass of #80.
    Not trying to be difficult, just picking your brains
Thread Information
Users Browsing this Thread
Similar Threads
  1. which speed on rotary?
    By dustleet in forum Detailing 101
    Last Post: Feb 26th, 2009, 02:34 AM
  2. Replies: 8
    Last Post: Feb 16th, 2009, 11:15 AM
  3. Rotary speed
    By sekyen in forum Mastering the Rotary Buffer
    Last Post: May 12th, 2005, 07:04 PM
  4. g100 speed with products ?
    By siblues in forum Detailing 101
    Last Post: Dec 23rd, 2004, 10:40 AM
  5. M-83 and Rotary Buffer Speed?
    By George Wax in forum Detailing for dollars
    Last Post: Dec 14th, 2004, 01:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
