Two Qs....Why would white car eventually turn yellowish white? and....
Results 1 to 10 of 14
Thread: Two Qs....Why would white car eventually turn yellowish white? and....
    Can I call myself a pro now?
    Nov 2006
    Jakarta, Indonesia
    50
    12
    I am not sure if this's been asked or not.
    But I am wondering why would such thing happen? I have seen it so many times, they all turn yellow eventually. What's wrong and how can we avoid such thing?
    Another question is...pardon me if it's not in the right forum.
    It's just the basic question evaluating a car's paint.
    What causes the car's paint to oxidize? is it UV?
    If in fact it's oxidized, is it on the clear coat?
    How can you tell if the car's paint is badly oxidized but stll can be restored or the paint just lost its clear coat and fades which usually turns white?
    They both look white but I can't tell which is which. Also car looses its clear coat need paintjob but badly oxidized paint needs detailer, am I corrent?
    Registered Member grover's Avatar
    Jul 2004
    152
    15
    Re: Two Qs....Why would white car eventually turn yellowish white? and....
    My guess is that you've witnessed white cars turn yellow because of oxidation. If the car's finish is kept clean, I don't see why it couldn't stay white.
    Here's an example of heavy oxidation on my car and how I fixed it using the DC system and elbow grease:
    turned to this:
    Registered Member Jeepster04's Avatar
    Jul 2006
    Eastern Kentucky
    1,235
    24
    Ive heard #26 turns a car yellow... Hahaha, sorry, I had to say it..
    Thats not true at all.
    37
    18,960
    233
    Well, one thing to remember is that a lot of dirt, esp if pollen has built up, is a yellowy brown color, not black. It is just that white will naturaly show this brown dirt more than a blue, red, etc colored car.
    Clear coat paints seem fairly resistant to oxidation, but on SS paints this is also a possiblity.
    Either way, it is just a matter of keeping after it, using clay/cleaner to get the dirt off, then polish and protect.
    Well, the oxidation is probably a little more complex than that. UV might help, but I am sure acid rain, hard water, other chemicals in the water/air, all are going to react with the paint more as it gets older.
    As mentioned above, CC are somewhat resistant to oxidation, but either way, it is the top of the paint that is oxidized. So if the CC is on top, then it is the CC that is oxidized.
    Actualy, if it is white, then the CC is still there, it is just failing. But it cannot be fixed at that point, only by a painter. When in dount, get some paint cleaner, and do a test spot.
    57
    24,779
    517
    Dirty paint? Stained paint?
    Whether it's a single stage or a clear coat.
    Darth Camaro 12/27/15 Don's Avatar
    NE Ohio
    51
    1,760
    32
    Mike, you did an article on white paint, but I couldn't link to it or cut & paste it to the forum?
    Don
    12/27/2015
    "Darth Camaro"
    2013 Camaro ... triple black
    323 hp V6, 6 speed manual
    Self-Banned STG's Avatar
    Apr 2004
    572
    0
    My guess is that ALL paint will stain/discolor/deteriorate. The color white just happens to highlight any changes.
    37
    18,960
    233
    Quote Originally Posted by Don View Post
    I believe you are refering to "A Lesson from White Paint."
    It should be available at Autotopia.com, or Showcargarage.com. They changed the links I think, but it should be there still.
    alberto gorin
    Nov 2006
    585
    17
    dumb qeustion i thought oxidation is rust or am i wrong ?
    sory for dumb qeustion
    37
    18,960
    233
    Rust is one type of oxidation on metal.
    On paint, oxidation is more of a chalky, dead paint sort of thing. where most of the oils have left, or reacted away from the surface.
  1. Best way to remove yellowish from white paint with G110?
    By skylinelks in forum Detailing 101
    Last Post: Dec 15th, 2008, 07:57 AM
  2. Trying to make a not so White car, White again
    By MDetail in forum Show Off Your Latest Detail Work
    Last Post: Feb 3rd, 2008, 01:08 AM
  3. White car :(
    By FEINT in forum Detailing 101
    Last Post: Jan 4th, 2007, 06:53 AM
  4. White car the one what to do?????
    By snowflakes in forum Detailing 101
    Last Post: Dec 15th, 2006, 09:13 AM
  5. White car, #80 and the PC
    By effxs in forum Detailing 101
    Last Post: Jan 17th, 2005, 07:55 PM
