I just purchased a clay kit (along with a bunch of other Meguiars products) and I'm wondering if the bar is re-usable. I have a newer vehicle so the impurities aren't that bad. Can I keep the bar in a zip-lock bag and use it again in the spring? Thanks
Clay Bar
Re: Clay Bar
If the clay isnt bad, yes, it can be put in a baggy and re-used. Just put a spray of QD in the bag.
Just to mention, if you clay paint, then you can use it again on paint. Even on glass/trim is ok. But if you use it on your wheels, exhaust tips, or drop it, just throw it out, or save it specificaly for those areas.
I like to cut the clay up into smaller pieces, for that reason, so I dont waste a bigger block.2017 Subaru WRX Premium - WR Blue
Re: Clay Bar
Well, if it looks dirty I wouldn't reuse it. That said I have reused my clay, I keep my truck rather clean and the contaminates removed by the clay are minimal and the clay still looks nearly new I will reuse it. Not sure the exact clay kit you have but if you have a single bar, make sure to cut it in half and set one aside should you drop one half.Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
Re: Clay Bar
Originally posted by Murr1525 View PostJust to mention, if you clay paint, then you can use it again on paint. Even on glass/trim is ok. But if you use it on your tires, exhaust tips, or drop it, just throw it out.
Murr brought something up, now I keep my dirtier clay and use it just for the windows and exhaust tips.Brandon
