I use PPG 2042 speed clear over artwork on motorcycle parts. About 48 hours after painting, the parts are sanded to 2000 grit, polished with M-84, then 82 using the G100. Reading here, the 84 isn't the ticket. It's very slow but my results have been good. I tried the 83 but, in my very unprofessional experience, found that the 84 worked better. Set me straight, PLEASE!
Polishing Out Fresh Clear
Re: Polishing Out Fresh Clear
Hey, whatever works, works.
You normally wouldn’t use #84 with the G100 because there’s a good chance of hazing out an initially glossy finish (and many folks would stop there and panic) and it might be difficult to remove the hazing. Since you’re working a sanded surface hazing isn’t the issue. The issues are whether or not the process is aggressive enough to remove sanding scratch and then if you can work it to final gloss.
#83 is the most aggressive product recommended for the G100 but neither is intended to remove sanding scratch.
If what you’re doing is working for you and your paint system that’s what counts. (Also, if something goes very wrong you’re in a position to sand it all off and start again. So you have a lot of freedom to experiment.)
It’s not surprising that the #84 is slow for you. To remove sanding scratch you’d normally use #84 or the more aggressive #85 with a rotary.
PC.
Two things,
The dual action polisher is not effective, (in most cases), for use to remove sanding marks because it has a clutch that stops the spinning motion when too much pressure is applied. Removing sanding marks means removing paint, in order to remove paint you need a buffing pad moving across the surface to effectively abrade and remove small particles of paint.
The rotary buffer because it's a direct drive tool is very effective at removing paint, the dual action polish is not. The dual action polisher is safe and gentle to paint, these are the reasons enthusiasts like it, they learn that it is a tool that won't burn through their paint or instill swirls, but the reason it won't do these things is because it's safe and gentle.
When removing sanding marks you want something that is the opposite of safe and gentle, you want a tool with some power, unstoppable power and that's the rotary buffer.
2) M84 uses diminishing abrasives that require the power of a rotary buffer to effectively work against the paint to remove paint and break the abrasives down.
You might look into getting a rotary buffer if you're going to be doing this a lot, if it's just a one time paint job, then maybe you can borrow one from someone.
when you go to buff out a gas tank, unless you have a special jig to hold it or it's mounted to the bike, you'll want to find someone with strong arms and that you trust to hold the tank while you do the buffing.
Kind of like the way this young man is hold this guitar while it's being buffed so the guitar doesn't end up on the floor.
If you're going to continue with the dual action polisher then you can try spending more time with the M83 cleaner/polish.
Originally posted by road hog View PostSet me straight, PLEASE!
Support Our Troops - Tuesday, December 5th, 2006
