Deep scratch in plastic
  • Deep scratch in plastic
    I got my truck with a deep scratch in the lower body molding. It’s about 1/16”-1/32” deep, thru the paint into the plastic. You know when you bend or break plastic it turns white, I’m thinking that I could wet sand the plastic just to get rid of the white plastic on the surface. The plastic seems to be solid black. I know this won’t give me perfect results but I’m hoping that it will look better. I have 2500 & 1500 grit sand paper; maybe do some touch up with Scratch X.
    Anyone have any suggestions?
    Thanks in advance!
    P.S. I've learned a ton here so far, thanks to everyone for posting such great info.
    Scott
    Re: Deep scratch in plastic
    Cant wait to see how the final result will turn out. goodluck
    Yusri Omar
    Perfectshine Detail
      Well, I did not have any luck fixing this last fall. So I am going to try again this spring. I tried to sand off the white, with no luck. Maybe this is just one of those things I need to take to a body shop. Let me know what you all think.
      Thanks in advance!
      Scott
