No Pressure from water tank to pressure washer?
  • No Pressure from water tank to pressure washer?
    I have an enclosed trailer with a water tank. I hooked a garden hose which runs from the tank to the pressure washer. It had been working great now it's not working at all? Any ideas?
    Deland Mobile Detailing Service
    Re: No Pressure from water tank to pressure washer?
    maybe its your pump on the pressure washer......i also run a gravity feed system and no problems so far..iam just taking a guess that it could be the pump.....i also found out running a bigger hose from tank to p/w i get better pressure than with the garden hose and less chance of it kinking and messing with the pump...
    RZ AutoDetailing
    My Gallery
      It's not the pump, I brought 2 new pressure washers and hooked both of those up as well and it's the samething. Where could I find a bigger hose?
        I also found out that when i take the lid off the tank to give it air it also flows better,you can get bigger hoses at a plumbing supply or try homedot and lowes..
        RZ AutoDetailing
        My Gallery
          thats the problem i have . i was going to buy a 12v pump but not sure how that would work or how to set it up
          unscrewing the tank lid does help alot!
            I have a low profile 55 gallon tank in my truck. I use a 12V on-demand pump by Shurflo(i think). I connect a car battery and charge it once aweek. Works good for me on my electrick pressure washer. You could also wire a cigarette lighter plug up to it and just plug it into your vehicle.
