Results 1 to 8 of 8
Thread: Bird poop on clean car
    Jul 2006
    16
    12
    how do I clean this off w/out rewashing the car? If I just use a damp cloth, will it scratch the paint?
    Oct 2005
    31
    312
    16
    You can use an ample amount of quick detailer spray, such as Meguiars Quik Detailer, Nxt Speed Detailer, or any of the other professional and detailer line products. Use a good microfiber cloth, and make sure the surface is cool.
    Also, jmo, if it was my vehicle, I would just re-wash it.
    Registered Member Jeepster04's Avatar
    Jul 2006
    Eastern Kentucky
    1,235
    24
    I usually just wipe it off with a damp cloth. Im not going to wash the entire jeep just b/c bird poo is on the hood.
    Nov 2005
    210
    15
    I normally use #34 Final Inspection to remove bird poop, however as mentioned previously Quick Detailer should also do the job. My honest opinion is that washing the whole car is overkill, however it's up to you.
    '96 Honda Prelude
    www.vbautodetailing.com
    Registered Member Stangfan's Avatar
    Jul 2005
    111
    14
    Re: Bird poop on clean car
    As long as the paint is cool, soak a cloth in water and then just lay it on the spot for a few minutes. This will allow the water to soften it up. Then just use your detailer spray and a microfiber and poop-be-gone. Done right, you get a nice clean car again with no fear of scratching.
    1968 Mustang Coupe Candy Apple Red
    1990 Limited Editon Mustang 5.0 Convertible (7UP Car)
    Registered Member Zet's Avatar
    Apr 2006
    Denmark
    213
    14
    I think it depends on how big the bird bomb is. For small/flat ones, I think soaking it and removing with QD/MF is fine. But there's a lot of "stuff" in some bird bombs, like plant seeds, cherry pips (is that what it's called?), and the gravel sized stones that some birds eat to aid digestion, which will all tend to scratch the paint. So for big bird bombs I prefer to rinse them off, and wash the car aftewards.
    "Now Biff... make sure that we get two coats of wax this time..."
    - Back To The Future
    Jun 2006
    136
    I live in a heavily wooded area, but stay parked under carport when at home. At work, I'm out in the open. Amazingly, I've had poo land on car only once since purchased 4 months ago!!!!
    I found QD (totally saturated area) and a MF worked great (wiped gently after "blotting" most of it up first). I washed the car the day before and wasn't about to do it again!
    Dec 2005
    29
    I agree with everyone else,about using plenty of QD,soft towell,but you need to try and look at the 'type' of bird poo,because some droppings will contain grit/gravel,as birds use this to aid digestion,so be very carefull of wipping anything without inspecting it first.FWIW,my father gave me a good tip,many years ago about how to neutralise the acid content in bird droppings,quickly whilst still fresh,which was to 'spit on them' yes your own saliva would work to minimize acid etching.This was from the 'old days' with mainly solid colour paints (single stage).
  1. Target practice (bird poop)
    By Graeme in forum Detailing 101
    Last Post: Dec 11th, 2006, 08:48 AM
  2. Bird Poop
    By guns in forum Detailing 101
    Last Post: Feb 28th, 2006, 12:15 PM
  3. new paint + bird poop + other questions
    By sleepycoupe in forum Detailing 101
    Last Post: Nov 10th, 2005, 09:18 PM
  4. Bird poop
    By medazzaman in forum Detailing 101
    Last Post: Oct 19th, 2005, 02:24 PM
  5. Bird poop
    By nhernandez in forum Detailing 101
    Last Post: Aug 27th, 2005, 08:49 AM
