Would Meguiar's Hard Water Spot Remover.....
Results 1 to 4 of 4
Thread: Would Meguiar's Hard Water Spot Remover.....
    Aug 2006
    12
    ....work on a car's paint? I've tried the ScratchX remover, but the water spots are in there really good. The car was left next to water sprinklers before I bought the car.
    57
    24,779
    517
    Re: Would Meguiar's Hard Water Spot Remover.....
    Hi Eks,
    Welcome to Meguiar's Online!
    Meguiar's Hard Water Spot Remover was never formulated for or tested for use on automotive paints. Some people have had good luck with it but we're afraid that from your description of your water spots, our Hard Water Spot Remover isn't going to be the right product for the job.
    Below are two articles that will explain the issue you are dealing with which in a nutshell revolves around you removing the paint around the water spots to level the surface and in effect remove the water spots. By hand this can be a lot of work and even impossible.
    Here you go...
    In order to remove a scratch out of anything, metal, plastic glass, paint, etc. You must remove material around the scratch until the surface is level or equal to the lowest depths of the scratch or scratches.
    The below diagram if for paint, the the same thing applies to just about an surface material or coating.
    In essences, you don't really remove a scratch, you remove material around a scratch.
    Then the big question is, is the material or coating workable, as in can you abrade small particles of it and leave behind an original looking surface. For example, some things you can abrade, (remove the scratch), but you can never completely remove all of your abrading marks, thus you can't really fix the problem, all you can do is exchange one set of scratches of a different set of scratches.
    The next questions is, how thick is the surface material you're working on or the coating. You are limited to what you can do by the thickness of these to things, (surface coating or surface material), and whether or not this surface is workable.
    Sometimes you don't know what you can so until you try. It's always a good idea to test your choice of products, applicator materials and application process, (By hand or by machine), to an inconspicuous area. If you cannot make a small area look good with your product, applicator and process, you will not be able to make the entire surface look good. It's always a good idea to test first and error on the side of caution, versus make a mistake you cannot undo.
    How To Remove Water Spots off Automotive Paints
    Swirls, scratches and water spots are the three most common paint defects car enthusiasts struggle with when it comes to removing them and preventing them from coming back. In this how-to article we'll take a look at water spots, where they come from, how to remove them and also how to prevent them.
    There are two basic kinds of water spots or water marks found on automotive paints.
    • Type I Water Spots - Above Surface Mineral Deposits
    • Type II Water Spots - Below Surface Water Spot Etchings
    Type I Water Spots
    Type I Water Spots are what Meguiar's refers to as Above Surface Bonded Contaminants. A Type I water spot is some type of deposit, often times a mineral deposit that was suspended in the water source to begin with, then after the water evaporated off the finish the mineral is left behind where it bonds to the finish usually in a circular or pattern or shape.
    Type I Water Spots - Mineral deposits sitting on top of the paint
    How to Remove Type I Water Spots
    If you discover Type I Water Spots on your car's finish, it will often times require the use of both detailing clay and a paint cleaner to completely remove all trace of the mark left behind.
    • Step by step process for removing Type I Water Spots
      Step 1 - Wash & Dry the Car
      First wash the car thoroughly using a quality car wash to remove any loose contaminants and to also remove any portion of the mineral deposit that has not yet bonded to the paint. After washing the car, dry the car to remove any standing water and to prevent further accumulation of Type I Water Spots.
      Step 2 - Clay the Paint
      Use Meguiar's Smooth Surface? Clay Kit to clay all affected paint panels. Meguiar's Detailing clay is a special clay that you knead into a wafer or patty, somewhat like a pancake, and then rub over the finish using Meguiar's Quik Detailer as a lubricant between the clay and the paint. As you're rubbing the clay over the finish, the specialized abrasives will loosen and remove any deposits sitting on top of the paint and trap them into the clay and our clay will do this without instilling scratches into the paint.
      Because as you're claying, you're removing these mineral deposits and trapping them into the clay itself, you'll want to take your clay patty and fold it into itself and then re-knead it to expose a fresh side of clay. Also keep a microfiber polishing cloth handy and wipe down the clayed area as you work to remove any excess Quick Detailer from the paint so that you won't have to re-wash the car.
      Repeat the above process until you've clayed all of the horizontal panels on your car and possibly even the vertical panels should you discover Type I Water Spots on the sides of your car's paint.
      Step 3 - Clean the Paint with a Paint Cleaner
      After claying the finish, re-inspect the affected areas, the paint should look smooth and clean as well as feel smooth like a piece of new glass. If you see any trace outlines in the paint where the water deposits were previously, then you'll now need to use a paint cleaner like ScratchX to remove these imperfections out of the paint.
      Any water spots or marks left in the paint after claying the paint are actually etchings in the paint and must be removed using a paint cleaner. Water Mark Etchings are what Meguiar's calls, Below Surface Defects, that is these water marks are where the mineral deposits, (left after the water evaporated off the finish), actually etched into, or ate into the paint. This is why the detailing clay did not completely remove these marks, it's because these marks are below the surface and detailing clay only removes contaminants sitting on top of the surface.
      ScratchX is a paint cleaner that uses Meguiar's Microscopic Diminishing Abrasive Technology to safely remove swirls, scratches and other below surface imperfections out of the paint. Simply apply ScratchX using a clean, soft foam applicator pad and then work the product against the finish with firm pressure. Work a small area or directly on the affected area for 2-3 minutes and then immediately remove any leftover product from the paint and inspect. If the mark is no longer visible, apply a coat of wax to protect the paint. If the mark is still visible, then repeat paint cleaning step using ScratchX. Some swirls, scratches and water spot etchings will require multiple applications to remove depending on how hard the paint is and how deep the defects are.
    Type II Water Spots - Etchings below the surface
    Type II Water Spots are what Meguiar's refers to as Below Surface Defects. A Type II Water Spot is actually an etching in the surface where whatever was in the water was strong enough in its chemical composition to actually eat or dissolve the paint and thus etch into the paint.
    Close-up of same photo above
    If you discover Type II Water Spots in your car's finish, you can use a paint cleaner by hand such as ScratchX and the procedure outlined above in Step 3 for removing below surface etchings left by Type I Water Spots, or you can use a machine applied product such as a Meguiar's paint cleaner, or cleaner/polish to remove the water spot etchings using Meguiar's G100 Dual Action Polisher.
    Meguiar's Dual Action Polisher will safely clean your car's finish removing a small amount of paint in an effort to level, or smooth-out the paint. The goal is to remove just enough paint to level the upper most portions of the surface with the lowest depths of the defect you're trying to remove. In some cases you may want to check with a seasoned professional for their advice before attempting to remove below surface defects like Type II Water Spots.
    Important Note: Anytime you use detailing clay and/or a paint cleaner on your car's finish, you need to reapply a coat of wax to the paint as detailing clay and paint cleaners will remove any previously applied wax off the paint.
    How to prevent water spots from coming back
    There are two important things you can do to help prevent water spots from coming back, one is to remove water from the finish before it can dry and potentially leave a water spot. Meguiar's offers a number of different tools to help you do this including, our waffle weave Water Magnet Drying Towel, our Microfiber Super Suede Drying Towel, and our Super Thick Natural Chamois which comes in 4 different sizes.
    Besides keeping water off your car, the next best thing you can do is to keep maintain a good coat of wax on all the painted surfaces, to help with this Meguiar's offers a number of different waxes to suit everyone's preferences including, NXT Generation? Tech Wax, Gold Class? Liquid Wax and Deep Crystal System Carnauba Wax.
    57
    24,779
    517
    By the way, both of the above articles were taken from the Information Station where you'll find a plethora of helpful information.
    Here's the link....
    http://meguiarsonline.com/forums/for...?s=&forumid=82
  1. marine line Water spot remover
    By Chex in forum Detailing 101
    Last Post: Oct 6th, 2006, 07:10 AM
  2. #47 Hard Water Spot Remover
    By fgraciano1980 in forum For Sale or Trade
    Last Post: Jan 24th, 2006, 05:49 PM
  3. Hard Water Spot Remover
    By RedSoxRacer in forum Detailing 101
    Last Post: Jul 27th, 2005, 04:01 PM
  4. Water Spot Remover
    By Rockpick in forum New Product Suggestions
    Last Post: May 9th, 2005, 03:29 PM
  5. water spot remover
    By DSG Man in forum Detailing 101
    Last Post: Oct 3rd, 2004, 04:40 PM
