Removing Carbon from Engine Compartment
Results 1 to 10 of 12
Thread: Removing Carbon from Engine Compartment
    Registered Member jpierre's Avatar
    Jun 2006
    32
    12
    How do I remove carbon deposits in the engine?
    Self-Banned RedSoxRacer's Avatar
    Aug 2004
    205
    0
    Drive it at red-line for a while
    Registered Member Tecumseh TJ's Avatar
    May 2006
    I have used "Mopar Combustion Chamber Cleaner" before with
    good results. you can get it a any chrysler dealer for about $7 a can. Just take your air intake tube off at the throttle body, start your engine and while holding the idle up just a little, you spray the whole can in the throttle body (alot of little spurts). Shut the engine off and let it sit for at least an hour. It will dissolve any deposits in the engine. Start it up and it will smoke alot (about 15-20 minutes) while it burns off any product left in the cylinders. Another good idea is to change your sparkplugs afterwards too.
    Good luck.
    Sep 2006
    3
    12
    Re: Removing Carbon from Engine Compartment
    I have always been a fan of rotery engines. Which have a huge problem of carbon build up. Try putting a can or two of Marvel Mystery Oil in your gas tank every now and again, and it does a good job of getting rid of carbon build up.
    Its been the best product I have found thus far for my needs.
    Registered Member hammer55's Avatar
    Dec 2005
    62
    141
    14
    techron by chevron
    Jul 2006
    48
    12
    This stuff the best on the market. It's about $18 to $20 a can. You will need a funnel to pour it into your gas tank. Pour it into about a half tank of gas depending how big your gas tank is. I don't believe in cures in a can but this stuff works. It's called 44K.
    http://www.bgprod.com/products/fuelair.html
    Self-Banned STG's Avatar
    Apr 2004
    572
    0
    Techron is approved by Bosch for use in its fuel injection systems and is harmless to catalytic converters.
    Jul 2006
    48
    12
    44K is basiclly Techron but in the strongest form on the market. It will not harm your catalytic converter.
    Detailer for Hire GTBrad's Avatar
    Jun 2006
    35
    178
    I've used a product called Seafoam.
    It's been around for quite some time, it seems a little hard to find but I happened to snag a few cans at my local NAPA (however, I recently saw Autozone has stocked this item)
    Pour half of this can (slowly) into you intake manifold via vaccuum tube while the engine is running, then pour the remaining in the fuel tank.
    Rev up that motor and get into the high RPMs...I just romped around the block a few times topping out 1st and 2nd gear =)
    You'll notice plenty of smoke (so will the neighbors)
    I'd recommend a spark plug replacement and oil change after this is done
    -Brad
    Shine Masters Pasadena, CA
    shine-masters.com
    Sep 2006
    21
    12
    I heard seafoam isnt good for your engine is this true ? and that you shouldnt use it if your car has over 150000 miles.
  1. Engine Compartment Detailing
    By CharlesW in forum Engine Compartment Detailing
    Last Post: Jan 9th, 2009, 03:24 AM
  2. Engine Compartment
    By Taco5 in forum Detailing 101
    Last Post: Apr 6th, 2007, 10:33 AM
  3. engine compartment rust
    By kadidle77 in forum Engine Compartment Detailing
    Last Post: Nov 12th, 2006, 02:35 PM
  4. engine compartment
    By sneek in forum Engine Compartment Detailing
    Last Post: Oct 5th, 2005, 12:35 PM
  5. Detailing the Engine Compartment
    By Black Diamond in forum Detailing 101
    Last Post: Aug 31st, 2004, 02:01 PM
