Results 1 to 10 of 13
Thread: How to remove traffic paint
    Registered Member MandarinaRacing's Avatar
    Dec 2004
    38
    446
    It's driving me nuts
    I've tried claying, ScratchX, Tar Remover, heck even mineral spirits, and nothing seems to work....help
    Alex
    Registered Member sneek's Avatar
    Aug 2005
    2,750
    35
    just a wild guess but DC1 with a terry worked in very very well
    Registered Member Kevin Brown's Avatar
    Apr 2004
    688
    451
    If the paint is stuck to non-painted plastic (textured or smooth), it'll eventually loosen up due to expansion/contraction, oxidation, or out-gassing of the plastic. In other words, it'll eventually come off. Sometimes, use of a pressure washer will help things along. Applied liberally, M40 Vinyl/Rubber Cleaner & Conditioner will help to weaken the bond.
    If the paint-blob is stuck to automotive PAINT, and the paint-blob is thick (and nothing in the chemical realm works)... Use a plastic razor blade (or a brand new putty knife, taped with masking tape) to push against the paint-blob. Again, liberal use of the M40 will help. This method is a long-shot, but give it a try.
    If neither of these methods work, this one will:
    Oh boy, I can hear the screams in protest of this recommendation already)...
    1. Remove loose contamination (pretty obvious).
    2. Wax the area with the hardest wax you can find (a paste carnauba works well).
    3. Let haze, then wipe off excess residue.
    4. Use a new razor blade. Rub the blade-edge across some rough leather (like the backside of a belt). The motion should be as if you were painting with a paint brush... Back and forth. This will fine-hone the blade.
    Now, gently push the blade (at an appropriately slim angle) against the paint-blob, doing your best to avoid gouging the car paint (duh).
    The wax coat is a barrier, and will allow the razor to ride upon it. Sometimes you'll notice the wax being scraped away. If that's the case. re-apply and repeat the process.
    I've used this process dozens of times. A few times I did 'scrape' away a little paint, but it was not very noticeable.
    BIG recommendation that you get the feel for the razor on a junk panel before you make the attempt on your ride.
    FYI...
    Before there was such a thing as over-spray clay, a company used this method (with huge success) to remove paint overspray from vehicles (primarily for insurance companies).
    I used the method a couple of times to remove overspray, but it was too freaky for me!
    Kevin Brown
    Dec 2004
    38
    446
    Thanks for the recomendations, I'll try the M40.
    The paint specs are not that big, some on the rear bumper (plastic) and some on the rocker panel (textured paint)
    I have some #16 in case I need to use the "surgical" approach!
    Alex
    Registered Member LiquidBlack's Avatar
    Aug 2005
    531
    I detailed my mom's car for christmas, and she had road paint splashed all along the side of it. The paint had sat there for nearly three years.
    I ordered some plastic razorblades from Auto Detailing solutions. I also used clay. We would scratch at the paint a little bit, then clay, scratch, clay, repeat. It was a slow process, yet worked. Within two hours I think the majority of the splashed on paint was gone.
    After that I followed up with #83 on a w8006 pad at speed 5 to remove any marring caused by our process. After a few passes, the panels looked brand new.
    Proud owner of the finest looking car in the parking lot.
    Switch to Linux. Use energy efficient lightbulbs and appliances. Keep your car well maintained and drive easy to save gas. Eat less fast food. Call your mother and tell her you love her. Try flying a kite. Read a wikipedia article daily. Use Meguiar's.
    Jun 2005
    613
    15
    I was able to get it off freshly waxed surfaces with just clay, but on some other surfaces it wasn't coming off at all. I used Langka's Blob Remover to get it off.
    Heh heh, I like plastic razor blades for all sorts of stuff (and I can see using a regular one if you have the touch), but if I can avoid marring my paint I will The Langka worked great and there wasn't any marring to polish out.
    Practical Perfectionist
    Feb 2004
    189
    Simple... WD40, it will easily dissolve road paint.
    Leo
    Aug 2005
    531
    Just to be sure, can anybody testify to this? Can anybody else say WD40 takes care of road paint?
    Professional Detailer Jimmy Buffit's Avatar
    Indianapolis, IN (Carmel)
    292
    12
    Road paint canbe quite difficult. So many variables are in play. Trial and error works best for us... Start with the least aggressive method...
    Kevin, I need to learn how to spell "cajones", cause you got some big ones!!!
    I'm gonna practice that one. Now, how can I get road paint on a junk panel???
    Jim
    www.jimmybuffit.com
    Apr 2004
    688
    451
    Jim
    Very FUNNY !!!!
    If anyone can pull off this method, an NXTti grad like you can!
    BTW... I enjoyed that pic you posted... You know, the one that was on for almost a day...
    Kevin Brown
  1. Help! Traffic ticket?
    By Wolf-Strong in forum The Break Room
    Last Post: Aug 20th, 2008, 09:43 AM
  2. how do you remove paint overspray?
    By CreamPuff in forum The Dual Action Polisher
    Last Post: Aug 4th, 2008, 07:08 PM
  3. How can I remove spray paint from car paint
    By jpfaile in forum Detailing 101
    Last Post: Jul 14th, 2008, 07:18 AM
  4. Replies: 4
    Last Post: Feb 5th, 2007, 08:38 AM
  5. Traffic pet peeves
    By cydewaze in forum The Break Room
    Last Post: Dec 11th, 2005, 12:49 PM
