Results 1 to 5 of 5
Thread: engine compartment cleaning
    Jan 2006
    152
    14
    I will clean/detail my engine compartment here shortly, what does everyone recommend for products/methods? I just want to get it cleaned and protected-everything is pretty much stock so there won't be much "bling" when I am done (its an '81 camaro).
    Registered Member Newport Viper's Avatar
    656
    21
    We used Meguiar's All Purpose Cleaner.
    ( Keep wet, don't let dry.)
    Power washer.
    Aggitate with nylon brush.
    Tape and plastic bags for the electronics.
    Follow with Meguiar's Hyper Dressing!
    Wipe in product with rags.
    ( Thanks again Paulvr4!!)
    SRT-10 Silver
    Jan 2006
    152
    14
    I didn't even know this section was here
    Registered Member Ash Erickson's Avatar
    Mar 2006
    56
    I second that system. That is a great way to clean your engine compartment. Please be very careful when using water around the electronics. Take your time and cover all non sealed or sensitive electronic parts. Parts that we see that are very sensitive are O2 sensor, MAF, MAP, Air flow meter and any of the ignition. It also helps to use somewhat low pressure. Make sure to never use Hot Water. Hot Water can also be harmful to any electronics due to over heating of the components.
    Ash Erickson
    Marine / RV Sales & Training Rep.
    800.854.8073 Ext. 165
    aserickson@meguiars.com
    656
    21
    Even though a power washer was used, it was sprayed in short bursts only. Just enough to get the cleaner off. Use a brush to loosen most grime. Don't let any cleaner dry. Pre wet the motor before you spray any cleaner directly on it.
    SRT-10 Silver
  1. Engine Compartment Detailing
    By CharlesW in forum Engine Compartment Detailing
    Last Post: Jan 9th, 2009, 03:24 AM
  2. Engine Compartment
    By Taco5 in forum Detailing 101
    Last Post: Apr 6th, 2007, 10:33 AM
  3. engine compartment rust
    By kadidle77 in forum Engine Compartment Detailing
    Last Post: Nov 12th, 2006, 02:35 PM
  4. engine compartment
    By sneek in forum Engine Compartment Detailing
    Last Post: Oct 5th, 2005, 12:35 PM
  5. Detailing the Engine Compartment
    By Black Diamond in forum Detailing 101
    Last Post: Aug 31st, 2004, 02:01 PM
