How to remove 3M double sided tape?
Results 1 to 10 of 20
Thread: How to remove 3M double sided tape?
    Registered Member gbackus's Avatar
    Apr 2004
    South Gate California
    574
    20
    My truck has some 3M double sided type above the windows were it used to hold onto some of those wind deflectors, however I decided to take them off. On the passenger side the tape was quite old and I was able to remove it with only moderate difficulty using a plastic razor blade. However, the driver's side tape is fairly new and still very tacky. I've tried both plastic and steel(very scary to use on paint) razor blades and they both just seem to remove the top portion of the tape, leaving a very thick and sticky residue that refuses to come off.
    Anyone have any suggestions?
    I want 4" Softbuff pads!
    37
    18,971
    233
    Could try Goo Gone, or something like Bug/Tar Remover, or the Body Solvent.
    Jun 2005
    613
    20
    Yeah, a solvent-based approach along with the plastic razor blades. I usually use 3M Adhesive Remover. Try to figure out a way to hold a saturated cloth against the area to the solvent can dwell for a while (this might take some ingenuity).
    Yesterday I spent an incredibly long time (nearly 30 minutes, and that's after the soaking) removing some old adhesive from a BMW. I had a goofy-looking Rube Goldberg setup holding the saturated cloth against the area in question. Looked weird but it kept the cloth where I wanted it.
    Practical Perfectionist
    Registered Member SpoiledMan's Avatar
    Apr 2004
    582
    20
    George, have you tried giving it some heat with a blow dryer to loosen it up?
    Quadruple Honda Owner
    Black cars are easy!
    Registered Member kuhlguy71's Avatar
    Nov 2004
    Illinois
    67
    14
    I second that method. I had to remove a cracked window visor and heating it with a blow dryer made removing the tape so much easier. Once it has warmed up to where it's almost too hot to touch, it will virtually roll right off the paint with a rub of your finger.
    Apr 2004
    574
    20
    Thanks for the tips guys.
    I forgot to mention I did try body solvent, and it didn't seem to help much(also used safety solve from another company and no go). I'll try the blow dryer method before I go out and by some goo gone.
    Thanks guys Ill report back.
    Apr 2004
    574
    20
    Alright, I tried the heat, and I can see where it would work for OLD tape, but this tape is still pretty new and sticky, and the heat only made it stickier. I can remove the tape no problem, but it's the residue it leaves behind that's giving me issues. I guess I'm going to have to just try a stronger solvent like the 3M stuff.
    Registered Member magicman22's Avatar
    Mar 2006
    29
    try some rubbing alcohol
    Darren
    Nov 2004
    Illinois
    67
    14
    I used clay on the residue left by the tape.
    Registered Member KTruck's Avatar
    Apr 2004
    246
    17
    Hi:
    Another thing to consider is WD-40.
    Saturate a cloth and hold on the adhesive.
    Work on a cool surface and wash the area once you are finished.
    Regards,
    KTruck
  1. Double sided smaller Edge pads and adaptor
    By AeroCleanse in forum For Sale or Trade
    Last Post: Feb 15th, 2009, 09:45 AM
  2. double-sided tape residue
    By cypher_tdi in forum Detailing 101
    Last Post: Sep 9th, 2008, 02:48 AM
  3. Adapter for the Double Sided Wool Pad
    By chiathau in forum Professional Line - Mirror Glaze & Detailer Line Product Discussion
    Last Post: Apr 14th, 2008, 07:06 AM
  4. W5000 Double-Sided Wool Cutting Pad - New
    By Mike Phillips in forum Meguiar's Product Introduction Threads
    Last Post: Dec 11th, 2007, 10:59 AM
  5. Will 2 sided tape mess up your paint?
    By Cleetus in forum Detailing 101
    Last Post: Apr 24th, 2007, 11:56 AM
