Washing Microfiber Polishing Cloths - Laundry - Page 6
Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 64
Thread: Washing Microfiber Polishing Cloths - Laundry
  1. #51
    Registered Member HEMI1500's Avatar
    Sep 2008
    north fork LI NY
    90
    Re: Washing Microfiber Polishing Cloths - Laundry
    oh, and i know, no fabric softner
  2. #52
    Mar 2010
    Woodbridge, Va
    9
    Quote Originally Posted by roushstage2 View Post
    Wash hot with some APC and a bit of detergent. Rinse initially with some vinegar and keep rinsing until there is no more soap floating at the top (shouldn't really be any unless you used too much soap). Put in the drier and dry.
    What I am trying to understand is, wash it, when done, remove it from washer, rinse with vinegar for how many cup size for 2 microfiber towels?
    Where do I rinse the MF in the washer or in the regular bowl to soak it? Then put into the dryer as you mentioned. Thanks.
  3. #53
    Jun 2005
    The Real NorCal
    4,102
    142
    For two MF towels, you may save yourself the trouble of measuring vinegar and just rinse them in the sink under running water, wringing them out a couple of times just to make sure they aren't soapy still and then put them in the dryer. The vinegar helps when you have like fifty towels you are trying to do this to.
  4. #54
    Oct 2010
    California
    17
    8
    can i wash my Microfiber towels with APC+ or i have to use APC?
  5. #55
    Registered Member cadillacman91's Avatar
    Apr 2011
    Tooele Utah
    8
    In my experience, I've just washed my Microfiber towels the same way I would wash a load of T-Shirts or Levi's. Just use the regular amount of dish detergent for the size of your load.
    I have always used the warm/cold setting. (Warm water when they are being washed with the detergent, and cold for the rinse cycle.) The only difference is, when the rinse cycle comes, I don't add any fabric softener. I just let them spin.
    After they have spun, I put them in the dryer for a regular drying cycle, the same as you would for a load of T-Shirts.
    Here's where I get a little bit different, I keep the MF's that I have used for the paint, and the ones that I have used on other things, (interior protectants, tire and wheel cleaner, plastic trim protectants, glass cleaner, etc.) SEPARATE from the ones I used with the paint. I wash the ones that I used for the paint first, then the other rags. Often times if you use a rag that has been used to clean brake dust, wash it, and then use it on your paint, you are in for swirl city! I always make sure to keep them SEPARATE to elimate the possibility of swirls.
    Does that help? Sorry for such a long explanation.
    Last edited by cadillacman91; Apr 9th, 2011 at 10:18 PM. Reason: Wrong word choice in 2nd paragraph
    I've been told I'm obsessed with my car, but I've got the cleanest car on the block!
  6. #56
    Jan 2011
    charlotte north carolina
    12
    8
    Maybe I'm just paranoid, but I just washed my yellow mequiar's microfiber towels and dried (no fabric softener or dryer sheets), and I feel like they are "rougher" feeling than before.
    They weren't mega dirty. I like to wash them after every time I remove wax with them (I just got these, so it was one time). So basically, they were used once, washed, and dried (again, no dryer sheet or fab softener).
    They have to be safe to use, right? Again, I'm probably just paranoid.
  7. #57
    Sep 2008
    north fork LI NY
    90
    After you wash your microfibers say they were used for clay>swirlx and nxt 2.0..do you keep them seperated after washing for specific purposes? or do you just use them for whatever
  8. #58
    Registered Member Detailing by M's Avatar
    Jul 2011
    Rancho Santa Margarita Ca
    2,202
    29
    Quote Originally Posted by HEMI1500 View Post
    YES!
    Also you wash themseparatelyy too ie: don't wash wax and window towels together.
  9. #59
    Sep 2008
    north fork LI NY
    90
    I just screwed up then washed about 10 new ones 2 that was used to wipe off NXt and 3 used to wipe swirl x as well as a soft buff pad from the DA used with swirl x and a small hand pad used to apply NXT ,,all washed together and did a additional rinse cycle after the fist one was done
  10. #60
    Jul 2011
    2,202
    29
    wax and compound are ok to wash together.
    it's just the wax isn't good for your window towels
  1. How many microfiber polishing cloths do I need to detail my car?
    Last Post: Jan 7th, 2010, 07:12 AM
  2. Replies: 7
    Last Post: Jan 24th, 2009, 07:59 PM
  3. Costco Microfiber Polishing Cloths
    By Mikejl in forum Detailing 101
    Last Post: Aug 28th, 2008, 03:06 PM
  4. washing microfiber polishing cloth
    By andyo in forum Detailing 101
    Last Post: May 8th, 2008, 08:23 PM
  5. Question regarding microfiber polishing cloths
    By acr-c in forum Detailing 101
    Last Post: Mar 20th, 2008, 04:01 PM
