When I said qeustions I meant it.
Does Meguiar's make a hull or below water line cleaner? Or should I use a stiff wash brush and/or a pressure washer to clean areas below the water line with regular boat wash.
Does Meguiar's make polymer sealant for gelcoats?
Does Meguiar's make a medium compound for gelcoats?
Can Meguiar's gelcoat compounds be used with a PC and cutting pad or 6” wool pad or are they rotary only?
What type of gelcoat maintenance can be done to a boat, which is left in a slip throughout boating season?
Eric
