frustrated
  • frustrated
    well my first time useing pc hasnt gone as planned. used #9 with light cutting pad on black neon. the car looked great at first. but then i saw it in the dark with lights relcting off . it is coverd in swirls looks like i used a brillo pad on it. can anyone help
    Was your "light cutting pad" a Meguiar's pad?
    See the big picture, enjoy the details
      frustrated
      no, unfortunatly not but it is a name brand
        So many factors could be at play here, but since we're on the subject of pads....
        ....I wonder if this pad is too aggressive for the product and the finish you're polishing.
        Another question: how long did you run the product? Did you work it down to that last little bit of polishing film, or was it still fairly white when you stopped the DA and wiped?
          Was fairly white
            #9 needs to be broken down by running that DA longer than you may well have. By the time it's ready to wipe, it will be just a bit of the polishing oils in a light haze on the surface.
            With all other factors remaining constant, I'd think you will get better results working the product a bit longer.
              Thanks, I will try it again.....it's 9:30pm I better get to it!
                Just adding a little.... When I first started to use my PC I didn't work the product in long enough.
                For example, when I started to use #80 I worked it in for around 30 seconds, later after reading what others do on MOL 1.5-2 min gives better results, giving time for the product to work as it was designed.
                Brandon
                2007 Black Chevy Avalanche
                My Albums: Avalanche
                  Brandon
                    Re: frustrated
                    How did it look in the dark with lights reflection on it before using #9 with the dual action polisher?
                      It had halograms from body shop, but it seems like it's much worse after using #9.
                        It had holograms from body shop, but it seems like it's much worse after using #9.
                        If the body shop instilled holograms or buffer swirls, probably from a wool pad on a rotary buffer like Richard shared in this thread,
                        Then you'll probably need something more aggressive to remove these swirls like M80 Speed Glaze.
                        #9 is a very, very mild cleaner/polish and best results, (read best abrading ability), comes when it's applied using a rotary buffer.
                        Try a spot about a foot squared using the dual action polisher on the 5.0 setting with about 10 pounds of pressure and work this small area using overlapping motions. Buff for 2-3 minutes but don't buff to a dry buff.
                        For your last passes, lighten up your pressure and make a few more passes. Wipe this residue off immediately after you remove the machine using a clean, soft microfiber and then inspect.
                        Just to note, #9 is a very, rich, creamy polish, if you shake up the bottle and pour some out into your hand and feel it, it will feel like hand lotion. By itself, it will not swirl-out a finish. I suspect your pad is the culprit. Is this the stock pad that comes with some Porter Cable units?
                          No, it's an orange light cutting pad. seems pretty stiff also. Swirls on car do seem like they came from the pad. What is your reccomendation for pads if I use #80?
                            No, it's an orange light cutting pad. seems pretty stiff also. Swirls on car do seem like they came from the pad. What is your recommendation for pads if I use #80?
                            The orange cutting pads I've used and seen discussed are too aggressive for most people to use with a dual action polisher on a clear coat finish.
                            For the work involved and the results hoped for, do yourself a favor and get one of our W-8006 foam polishing pads and try this foam formula with your #9 Swirl Remover 2.0
                            A better solution would be to get our M80 Speed Glaze and use this instead of the #9 and your success is for the most part guaranteed.
                            If the swirls are deep and your paint is fairly hard, you may have to start with M83 to effectively remove them.
                            Check out the results on this black finish using M83 followed by M80 Speed Glaze.
                              Thanks Mike, you are the man! I will try your plan of attack. I have so much to learn. Thanks again for your expertise.
